P0751????
Old May 17, 2006 | 01:02 PM
Figz Z28's Avatar
Default P0751????
P0751 - 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear (SES) (OLD) (History) (Current) (Immature). Well i gotten this code several times, and the car seems to shift fine even at wot. My question is should i get my tranny rebuild or should i wait till it takes a dump?
Old May 17, 2006 | 01:12 PM
cablebandit's Avatar
my built ones always did that code.....it was funny when it would say no first gear and i was IN 1st gear
Old May 17, 2006 | 09:20 PM
s346k's Avatar
my tranny has shot that code for the last 10,000 miles. that's the only thing my tuner didn't delete regarding the transmission.
don't sweat it. high stall converters will trip that code...i only have ~100 passes on my tranny after that code shot , don't give it a second thought, you're fine.
Old May 17, 2006 | 09:38 PM
BubaGumpShrimp's Avatar
yes, get the code shut off. Sometimes the code will set but the car will work fine, other times it wont set and you will loose gears and be stuck in one. Just have it shut off, common problem when going with a stall over 3,200 rpm..
Old May 17, 2006 | 10:44 PM
Figz Z28's Avatar
Ok i set the code off, but what about P0753,56,58,85? Should these codes also be turned off? BTW thanks for the info guys.
