Ultra Thruster 4600....
Old May 1, 2002 | 10:44 PM
Slow Z28's Avatar
Default Ultra Thruster 4600....
alright, i'm trying to get rid of the vig3200 and step up to a real converter <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> anyways, i've read through all the other posts and how it's not good for bolt on cars. although that is what i will be using it for in the mean time as funds progress for the cam install. Now...
that converter and 4.10's with 28" e.t. drags still is not the best for a bolt on car. BUT, what about when i add the cam (224/224 581/581 114) Will that converter be ok along with that? Or should i still wait and go for the TP4400? Thanks.
Chris
Old May 2, 2002 | 09:06 AM
Mike Hoffpauir's Avatar
Default Re: Ultra Thruster 4600....
I've seen that convertor in a couple of cars (one on the internet and one locally) and I would just go with the tp4400. TP works--Hands down. But the UT has "yet" to produce the times. If you want a little more Yank does make a tp4600 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 2, 2002 | 04:29 PM
WILWAXU's Avatar
I run a UT-4600
Since you will be using it in your car with the stock setup.. I would go with the TP-4400. It will be great with both setups.
Old May 3, 2002 | 09:11 AM
Paul F's Avatar
I had the UT4800 in my bolt-on and heads/cam car and wasn't real happy with it. It ran good and 60' awesome but I really think I was leaving some on the table. With a 6600-6800rpm shift the rpms would never fall back past 6000, more like 6200. I have since switched to the PT4400 but I haven't been back to the track yet but the car feels much better.I really don't think you can go wrong with the PT4400. Too many cars out there have proven that it will haul a$$ no matter what the motor is.
<small>[ May 03, 2002, 09:12 AM: Message edited by: Paul @ Thunder ]</small>
Old May 3, 2002 | 11:14 AM
2000LS1Z28's Avatar
Just go with what is already PROVEN! Yank TP4400. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Mike
Old May 4, 2002 | 12:59 AM
JS's Avatar
JS
Paul I wouldve put a 430 or lower gear in and then tried your UT.It wouldve gotten alittle tighter and worked better according to Mike.But I agree,4800 is too much.
Thats good info u got Paul
If you were seeing 6000 drops on a 6800 shift point then a 4600 would theorectically drop me to 5800,THATS WHERE I WANNA BE,1000rpm off my shift point is ideal for my setup.
Will see?
JS
<small>[ May 03, 2002, 01:05 PM: Message edited by: JS ]</small>
Old May 4, 2002 | 09:45 AM
Paul F's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JS:
<strong>Paul I wouldve put a 430 or lower gear in and then tried your UT.It wouldve gotten alittle tighter and worked better according to Mike.But I agree,4800 is too much.
Will see?
JS</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree that the converter would have worked better with more gear but I really don't see a need to put 4.30+ gears in an auto car. Plus at the time my cae was seeing 100% street duty so that was out of the question.
You'll probably see about 5800 or so on shifts with the UT4600. My PT4400 is dropping back to about 5500 now. My power and torque band are so wide on my motor I really think that should help me. I just don't think I was using enough of my motor with the UT4800. Good luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Paul <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<small>[ May 04, 2002, 09:46 AM: Message edited by: Paul @ Thunder ]</small>
Old May 4, 2002 | 10:06 AM
JS's Avatar
JS
Paul I run a 28in tall street tire so the 4.56 isnt that bad.Plus I run the on 28in slicks too.
I put it in yesterday.
U werent kidding,ITS LOOSE.
If I dont get the results I want I can alway go back to a TP4600.Thanx for the help...
JS
Old May 6, 2002 | 09:00 AM
Paul F's Avatar
<strong>Paul I run a 28in tall street tire so the 4.56 isnt that bad.Plus I run the on 28in slicks too.
JS</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With a 28" tire that make since. I'm still on 26" ET Drags for now. It hooks awesome so as long as it does I'll stay with 26"s.
Yes it's loose but I like it take way. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Paul
