shift kit affect tune?
Old May 22, 2006 | 02:04 PM
00formLs1's Avatar
Default shift kit affect tune?
i got a tune at texas speed this spring and the line pressure was bumped up a tad, will adding a shift kit do any harm since the pressure was raised?
Old May 22, 2006 | 02:32 PM
my number 1 hater's Avatar
if anything if will shift even harder... i got a B&M street and strip. and a jet module they work GREAT... sec gear bark is SWEET. I have 160,000 miles no trans problems...installed a 69,000...
Old May 22, 2006 | 02:48 PM
steez's Avatar
...just get a polly tranny mount
Old May 22, 2006 | 06:06 PM
BlackHawk T/A's Avatar
I wouldn't run both. Modify it mechanically or electronically, not both.
Old May 22, 2006 | 06:14 PM
crazymofo1986's Avatar
bump im thinkin the same
Old May 23, 2006 | 04:30 PM
Bader-X's Avatar
My friend did both ... and something was wrong so I gave him a call and he said he programmed it to shift at 6000 rpm but after the shift kit it shifted at 5500 rpm the performance shop said that it`s not good to make both of them and he still did`t fix the problem .... my opinion (wich is without a real life experience is rais the shifting point with the programming and don`t raise the pressure) as it says when you use a hypertech programmer.
Old May 23, 2006 | 10:06 PM
RevGTO's Avatar
Pontiacerator
I have both and it works great. Shift points, shift timing, lock-up speed can all be adjusted electronically and it's not going to matter if you have a shift kit or not. The only supposed no-no is electronically raising line pressure if you have a shift kit. But the advisability of doing that would depend on how much you have after installing the shift kit.
