Tranny cooler install
Old May 23, 2006 | 01:01 AM
00cls1camaross's Avatar
Default Tranny cooler install
can anyone give me a write up on the tranny cooler install
i will be trying it at my house tomorrow
thanks
-dakota
Old May 23, 2006 | 05:01 AM
koolaid_kid's Avatar
http://www.bfranker.badz28.com/94Z/trannycooler.htm
Old May 23, 2006 | 08:27 AM
thanks mr. koolaid guy
Old May 23, 2006 | 03:20 PM
Strahley's Avatar
Keep in mind that's only one of many mounting places you can do. If you do a FTRA or anything like that, I don't think that mounting spot will work very well
Old May 23, 2006 | 03:21 PM
CrawlinWS6's Avatar
Import Patrol
Make sure you bypass the radiator. The trans will run much cooler, with out going thru the radiator!
Old May 23, 2006 | 03:57 PM
hum... why would that be? wouldnt 2 coolers work better than one?
and i have ssra
i still am thinking of a spot to mount it.... kinda tuff
Old May 23, 2006 | 04:40 PM
Strahley's Avatar
You know the two holes we have in the front grill of our Camaro's? My cooler is mounted right behind the passenger side hole. It seems to work great there, tranny temp stays around 150 in city (yesterday was nearly 100 degrees outside here I think) and on the highway/interstate it drops down to 125/130. Only thing is I removed my front bumper support (for weight) so there was tons of room for it. If you couldn't do that, you could try dope style
Old May 23, 2006 | 04:44 PM
Strahley's Avatar
Here's a picture of a dope style install. It's on the passenger side, front of the car, right under the fog light (this is not my car by the way)
Old May 23, 2006 | 04:58 PM
huh, i have heard of dope style... thinking of doing that
the behind the grille thing is neat... but i keep my bumper suppost since it has saved my life once already lol! stupid rain
Old May 23, 2006 | 05:10 PM
Strahley's Avatar
Probably a better idea to keep it on. I only take the car out to test it/race it on nice sunny weekend days anymore, so I guess I can get away with it. If the car saw the light of the world more I'd probably keep it on
Dope style should work fine for ya, it'll get plenty of air. If nothing else you could always install two coolers, one on each side, so you're doing it "double-dope style"
Old May 23, 2006 | 08:10 PM
yeah word... it sounds cool/fun! kinda bothers me though not having each corner mounted
then again it is light as ****... and the bad thing about dope style... another thing to have to watch out for when parting where there is a curb...
you can thrash so much **** if you parked you car up to close to a curb
Old May 23, 2006 | 11:14 PM
Strahley's Avatar
That's why I always park backwards now, so I don't have to worry about hitting the nose on anything
When you say not having each corner mounted, are you referring to the plastic from the car, or the corner of the cooler?
Old Jun 3, 2006 | 10:19 AM
FullBoreTA's Avatar
Removed mine after trying it between the AC condenser and then trying the "dope-style" location in the picture above. Last weekend, I removed the lower air dam that scoops air up to the radiator. Then I removed the plastic covering from underneath the car (real easy to remove) in front of the passenger side wheel. It now sits concealed just under the headlight ... where the horn is located. This allows it to sit directly behind the big air hole underneath the headlight and amber parking light. It also has fins which allows the air dam to push air from underneath the car and up directly into the cooler. It maintains the same temperature as the other places it was mounted previously. The advantages are; (1) the dope-style left it exposed; (2) the radiator mount was causing the motor to overheat in traffic when the weather is above 80+ degrees. Finally got it where I need it and I'm satisifed with the new location.
Old Jun 3, 2006 | 09:18 PM
TopFlite's Avatar
Mine is also mounted in the same location, resting on the front side of the radiator.
Old Jun 4, 2006 | 06:55 PM
can i get some pics?
Old Jun 4, 2006 | 07:39 PM
slimcracka's Avatar
nice video lol.....
Old Jun 6, 2006 | 12:13 AM
Malko's Avatar
just installed mine "dope" style as well. will be testing it tomorrow.
