ARP Pressure plate/Flywheel Bolts ?
Old May 8, 2002 | 11:01 AM
MIGHTYMOUSE's Avatar
Default ARP Pressure plate/Flywheel Bolts ?
Pace have these? what are the part numbers? Are they Identical specifications to stock except for stronger? Anyone use these, or do they not exist?
What about the shoulder bolts for the ram clutch? my friend needs these? from arp or ram? and part number please.
thaks dave
Old May 8, 2002 | 03:36 PM
Stick only's Avatar
Default Re: ARP Pressure plate/Flywheel Bolts ?
ARP only list american thread pp bolts, 130-2201 (HP) or 230-2202 (pro). RAM number is 490. Pace may have the GM metric factory bolts.
LS1 flywheel bolts are ARP 330-2802 (11mm).
Old May 9, 2002 | 10:38 AM
so ARP makes them, just doesn't list them..
the last number ARP 330-2802 (11mm) these are the pressure plate bolts correct? now i just needt to track down the crank bolts.
Old May 9, 2002 | 06:38 PM
Stick only's Avatar
no the 11mm are flywheel to crank.
