TH400 leaking problems....HELP.....
Old May 8, 2002 | 07:30 AM
BIGBOS's Avatar
Default TH400 leaking problems....HELP.....
I had this TH400 Trans installed by a local installer, we have tried EVERYTHING to stop the thing from dripping...it leaks from the front and the back of the trans pan, if I put the car on rhino ramps it leaks from the back, if I level it off it leaks from the front in the back...the first pan that was on there was the original pan, it didn't leak at first, but then started, then we put a chrome pan on there with RTV sealent, it still leaked, then they put an expensive aluminum pan on there with a rubber gasket and it still leaked, then we tried the same aluminum pan with a rubber gasket and silicone...It didn't leak for them, but as soon as I started driving it and got it home it started to leak again...this is starting to become a nightmare for the both of us...
Any ideas that anyone can come up with to stop this? I can deal with it because its only a 5" by 5" puddle every morning, but if it can be stopped I would like it to... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks,
Bos
Old May 8, 2002 | 08:40 AM
Shon Herron's Avatar
Default Re: TH400 leaking problems....HELP.....
The mounting surface either on the trans or the pan is not flat, sounds like the trans is not flat, what to do.....get some of that Lucas stuff, HA!! just kidding. I dont know what to tell you on that deal.
Old May 8, 2002 | 11:40 AM
JimmyKash's Avatar
Go back to the older thread and see if you've tried any of the things i told you
you should be using NO RTV and be using a cork gasket put up DRY or possibly use some spray red rtv stuff
Old May 8, 2002 | 07:05 PM
CoopDog's Avatar
With the RTV, did you let it dry for a good long time before filling with fluid again? This has happened to me, though not on a tranny. I usually try to dry RTV over night before I use it with alot of fluid contacting it, especially under any pressure. Hope this might help.
John
Old May 8, 2002 | 08:39 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
One thing that people do that is a big error is overtightening the bolts in the pan. Just put them good and snug. Too tight and the gasket squeezes out of place/cracks.
Check you tranny for a defect if you notice it coming from the same spot each time.
Tim
Old May 8, 2002 | 08:46 PM
flyin red TA's Avatar
Big bos, any regrets going with the TH400? Wish you still had the 6 speed?
A 5x5 puddle everyday is a lot, in my opinion.
Old May 8, 2002 | 09:59 PM
BIGBOS's Avatar
no regrets at all, its AWESOME and more and more people are starting to do it...that 5" puddle is probably like 10-15 drops, it spreads around pretty good.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 9, 2002 | 02:25 PM
Superman's Avatar
"a local installer" LOL
How come no "Izzo`s the best, the geatest" when something doesn`t go right?? <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> Where`s Joe, I need a refresher about how good the Izzo trans is <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> he he
I`m just messin with ya, sounds like a dooozy.
Tom thinks I don`t like him.. he`s wrong, he does good work and I`m sure you guys will figure it out... Good luck.
<img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Old May 10, 2002 | 07:36 AM
BIGBOS's Avatar
Well I didn't want to mention it, I was the first car hes ever done this conversion to, its not a problem, its just annoying... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Tom and the guys over at Speed Inc. are the greatest, they have tried a lot to fix this problem and now were are thinking its a defect in the actual case of the trans, so we might swap...who knows...
