Separator plate???
Old Jun 10, 2006 | 09:41 AM
Rons 5.3's Avatar
Default Separator plate???
Anyone know the best place to get a separator plate for a 4l60e? new? used ? got one laying around? anyone? My genius brother bent mine on the shift kit install. Thanks Ron.
Old Jun 10, 2006 | 10:01 AM
8a8mfh's Avatar
Get a transgo plate from a sponsor here. don't even think of getting a used one out of another transmission.
Old Jun 10, 2006 | 10:10 AM
Rons 5.3's Avatar
Will do! I didnt realize a used one would be a problem, it didnt seem like a wear type of item. I'll check with the sponsors. Ron
Old Jun 10, 2006 | 10:47 AM
8a8mfh's Avatar
Yes they do wear around the check *****, the transgo plate is a little harder.
Getting one out of something else isn't a good idea because of different hole sizes, locations, etc. Unless you find one with the same code which is kind of time consuming.
Old Jun 10, 2006 | 10:52 AM
Rons 5.3's Avatar
Any sponsors wanna chime in that carry the trans-go kit, a separator plate and wants to reccomend a good stall for my application...I want to order all three items from the same place. thanks Ron
Old Jun 11, 2006 | 12:29 PM
Rons 5.3's Avatar
Last call! lol any sponsors want to help out?
Old Jun 11, 2006 | 03:53 PM
FLT's Avatar
FLT
I have them in stock with the updated check *****. Give us a call on monday.
Old Jun 11, 2006 | 03:59 PM
Honda Hunter's Avatar
Can someone explain more about the difference between the stock and the transgo plates. I'm using a modified stock plate and was wondering should I use the Transgo?
Old Jun 11, 2006 | 04:10 PM
FLT's Avatar
FLT
The transgo plate is a little thicker than oem plate. Both work very well with updated check *****.
Old Jun 11, 2006 | 04:39 PM
What's so good about the updated check *****? When ordering the plate and ***** from you what info is needed?
Old Jun 11, 2006 | 07:58 PM
FLT's Avatar
FLT
The updated ***** are made of a plastic material that isn't abusive to the metal seperator plate. Year, make and model would be the only questions that would need to be answered.
Old Jun 12, 2006 | 12:13 AM
Rons 5.3's Avatar
Im on it, I'll call you tomorrow! thanks, Ron
