A4 Line Pressure Question
Old Jun 10, 2006 | 07:10 PM
Honda Hunter's Avatar
Default A4 Line Pressure Question
After some googling I was able to find the following except a 0-400 hydraulic pressure gauge(does it have to be hydraulic?) Found severel others but say they are for messuring oil, gas, and water
Here's what I found. Could you tell me what can and cannot be used and if I could get these from one supplier?
Gauge:
Valley Instrument Grade A Stem Mount 2 1/2in. Glycerin Filled Gauge — 0-400 PSI
Brass movement with C shaped Boudon tube. 1/4in. NPT male connection. For use with air, gas, oil or water. Black enameled aluminum pointer, white aluminum dial and temperature compensating polycarbonate window. Glycerin filled to dampen pulse and vibration. Accuracy: ASME/ANSI B40.1 Grade A (2-1-2%).
* Range PSI: 0-400
http://www.northerntool.com/webapp/w..._357856_357856
48" steel braded hose:
http://store.summitracing.com/egnsea...4&autoview=sku
NX11148 D-4 (48”) Stainless Steel Braided Hose (Blue)
http://streetfighters-usa.com/store/nx_accessories.html
-03 Straight to Straight Hose Assembly
(Female JIC, swivel nuts each end)
PP-33348
48"
$25.0
http://www.paragonperformance.com/ASSYS.HTML
1/4 to 1/4 npt coupler:
HUSKY
1/4 In. x 1/4 In. NPTF Connector
Model HDB30200AV
1/4 x 1/4 NPT Female coupling. Easy to connect design.
• 1/4" x 1/4" NPTF Connector
• Heat treated steel provides extended life over brass.
• Zinc plated to prevent corrosion.
• Offers easy connection .
Store SKU # 661382
Internet # 169716
Catalog # 100007722
Price: $1.97/ea
http://www.homedepot.com/prel80/HDUS....jsp?pn=169716
1/4 to 1/8 npt reducer:
16126 1/4 NPT X 1/8 NPT MALE UNION CONNECTOR $4
http://www.nitrousdirect.com/nitrous-express.html
040-16126 1/4 npt x 1/8 npt male union connector
http://www.sudco.com/nx.html
So as mentioned above I would like to know is there one place I could purchase all this from and can a reguler 0-400 gauge be used to measure tranny pressure? Also what should my line pressure be at on a vac mod built 4l60E?
Old Jun 10, 2006 | 07:57 PM
FLT's Avatar
FLT
You need to find a hydrulic oil pressure gauge 0-400psi. Is this for testing purposes? I bought a set from MATCO tools along time ago. I could probably get you some info if you need it. As far as the pressures it depends on where engine vacuum is a idle. Normally at idle on our dyno I see pressures at 15in of vacuum around 75-100psi in drive. 0 vacuum 210-230psi in drive.
Old Jun 10, 2006 | 07:59 PM
Yes this is for testing purposes. If you could get me that info thatd be great.
Old Jun 11, 2006 | 09:23 PM
Greaseymec's Avatar
If you have a Granger in your area the carry a good assortment of guages, both pneumatic and hydraulic. http://www.grainger.com/production/info/ww-granger.htm
Mec
