everybody with a STALL come inside!!!
Jeremy
I don't know how much just the stall or trans or tune helped because I had it all done at once. the car shifts fast as hell and chirps the tires on the 1-2 shift and it tries to rip the tires off the car from a standstill. the stock stall and trans was lucky to squeak the tires on launch on the street and the horrid torque management killed the shift speeds but its a completely different car now!!
thus far gas mileage doesn't seem to have changed at all with the 40 miles a day of 50/50 mix of traffic and highway driving I do every day.
don't have track times however; my mpg currently is approx 22 city/hwy mix.
it took me a day to get used to it and now it feels "normal" to me. i also heard that there isn't much difference between a 3000 n 3500 as far as looseness goes.
two things you WILL NEED, tranny cooler n at least some DR's. tranny cooler for obvious reasons n DR's because you will need to re-learn how to launch your a4. i had yoko's es100's and they wouldn't hook to save my ***. upgraded to BFG's DR's and after small burnouts, they hooked pretty decent on a shitty track.
oh n, once i hit 40-45 mph, 4th kicks in n i can cruise at about 1800-2200 rpm, if that helps any.
I would budget aside about $1000. You probably won't spend all of it, but it's better to be safe than sorry. Expect to drop around a second from your 1/4 times too
There's no problem with going that big with a stock cam. I had a 3500 TCI and it was very street friendly and I don't know why you would go any smaller than that. 3600-4000 for a daily should be fine.
