PO748 after vaccum mod
Old 06-12-2006, 11:56 PM
fast01's Avatar
Default PO748 after vaccum mod
I just had a tranny built by CK Performance with the vaccum mod. Does this always throw a PO748 DTC? In New York if you're showing a DTC you fail inspection. Can this be deleted with HP Tuners? Other than that I'm real happy with the unit so far. Thanks in advance!
Old 06-13-2006, 01:31 AM
Dmoney's Avatar
I didn't get any codes when I did mine. The resistor that replaces the solenoid is not on right or came loose, and yes you can just delete it with HP Tuners.
