Tranny cooler location...
anyone put their cooler BEHIND the transmission? like where the cats would go? any other idea?
Chris
Currently I've got mine in front of the radiator right in front of the driver's side fan along with lower fan settings and a manual switch. My temps usually stay under 170. I haven't had it out in weather above 85 degrees yet, but it's supposed to be 100 here this weekend....should be a good test. I've thought about cutting the foam out behind the two 'nostrils' on the front of the camaro and stick a cooler behind each side. Plenty of airflow while moving, not close enough to a heat source to get too hot while sitting still. I do like the ability to force air through it with the fans while in traffic though....
just trying to think outloud
