a4 launch
Old Jul 7, 2006 | 03:17 PM
camkid's Avatar
ok so i tried reving it at 3500 rpm's today in netural and then threw it into drive like you said......omg its sooo fast now, i took off like a beaten red headed step child! so i took it to the track and roasted a c6 vette with no prob. i did it time and time again and my kill list keeps getting longer and longer! thanks guys for the input.....but the only thing is that after i did this technique about 6 times i have this loud clunking noise from the bottom of the car????? also some red fluid seems to spray out from under my car when i rev it....looks cool though, mabye i need naws for my car.
Old Jul 7, 2006 | 03:26 PM
camkid's Avatar
oh and also what i found out is that you can put the car into reverse and go about 5 mph and then throw it into drive.....sick dude burnouts!!!!!!
Old Jul 7, 2006 | 03:33 PM
camkid's Avatar
I Just Need Help With The Knocking Noises They Bug After A While...im Pretty Sure Thats Not Bad Though Right?
Old Jul 7, 2006 | 11:47 PM
camscam02's Avatar
My car loves leaving at around 3000 with a 3500 stall!
Old Jul 8, 2006 | 05:58 PM
LS1 Sounds's Avatar
Keep doing the neutral drops and the noises will go away.
Old Jul 9, 2006 | 09:03 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Old Jul 9, 2006 | 09:08 AM
227Hawk's Avatar
Depending on the stage mine leaves best about 2800 or i just sit and spin.
Hawk
Old Jul 10, 2006 | 10:31 AM
camkid's Avatar
well i need an ss hood now becasue my tranny dropped! anyone have one?
Old Jul 10, 2006 | 11:55 PM
01_ram-air's Avatar
Left foot brake, right foot gas.....stall it up to about 3000 rpm and let her rip. (Need a good tc though)
Old Jul 11, 2006 | 12:40 AM
00formLs1's Avatar
i got my best time flashing my converter, but i really haven't taken the time to try different stall speeds to see hoe it does. i might to out friday and see if i can find a stall speed that does better.
also i would do sick burnout in my probe by going as fast as i could in reveres then shifting to nuetral and reving to redline the into gear. but that was when i was dumb.
Old Jul 11, 2006 | 08:37 AM
BlackHawk T/A's Avatar
When you flash the converter (launch from idle) you are using your suspension's anti-squat to the fullest. When you stall it up with your foot on the brake, you are pre-loading the car and it isn't going to launch as well.
Old Jul 11, 2006 | 01:01 PM
  #32
Roarin_8's Avatar
I get a better launch preloading the car as opposed to flashing it from idle. Another member from here was flashing it from idle and he couldn't get the car into the 11s (Procharger car). I told him to footbrake it and he got an 11.7 and he still has more in the car.
Old Jul 11, 2006 | 01:02 PM
  #33
You also have to consider tire spin...flashing the converter is going to hit the tires harder, so you need to keep it under control.
Old Jul 11, 2006 | 01:27 PM
  #34
darrensls1's Avatar
I always have the best results when I put it in reverse, brake stall to 2000 rpm's, launch backwards, flip off the guy I'm racing in the other lane (while shouting something about Brian Spilners school of driving) and then spin the car around and switch to OD.
Or just put it in D, brake stall it a few hundred rpm's just to slightly preload the drivetrain (less stress on the rearend) and mash the gas pedal to the floor.
Either or
Old Jul 11, 2006 | 03:25 PM
  #35
Reject's Avatar
LOL wow i hope no one actually takes the bullshitting seriously and goes and trys to do a powerdrop on their car!
Old Jul 11, 2006 | 03:56 PM
  #36
chris93266's Avatar
i have a pro yank 3600 and can only foot brake to about 1800-2000 rpms. with this setup, i've only been to the track once, but it seems that the harder i launch the car the slower it goes. '99 formula 3.23s built a4 nittos and 335rwhp
Old Jul 11, 2006 | 04:23 PM
  #37
LS1 Sounds's Avatar
Something's wrong there... I can foot brake to > 2000 RPM on a Vig 2800. Are you getting tire spin or will the engine just not pull it to a higher RPM?
Old Jul 11, 2006 | 04:28 PM
  #38
Roarin_8's Avatar
Maybe he's not holding the brakes firm enough. I managed to footbrake mines to 4000
Old Jul 11, 2006 | 05:17 PM
  #39
chris93266's Avatar
i pump the brakes then hold as hard as they will go and then get tire spin at around 2000rpm. it is a PRO YANK 3600 EXTREME 4L60E/4L65E converter. i also have a 4l65e not a 60. it is a nitrous converter, so i was told that it won't stall up high and will be tight like this on motor. is this true or bs?
258mm, Posi Lock-Up Clutch w/Kevlar Linings, 6 bolt mounting lugs , lightweight billet cover, 3600 stall, 2.30 STR
Old Jul 12, 2006 | 08:40 AM
  #40
LS1 Sounds's Avatar
2000 is probably about right if you are on street tires.
By Brett Foote | 2026-06-04 05:00:17
