a4 launch
Old Jul 12, 2006 | 11:00 AM
  #41
chris93266's Avatar
cool, i was on nittos, but nittos at the track are not worth a crap.
Old Jul 12, 2006 | 11:54 AM
  #42
Roarin_8's Avatar
I am on nittos as well and managed to get the rpms past 3500.
Old Jul 12, 2006 | 12:20 PM
  #43
chris93266's Avatar
hmm what are the differences in our converters? what could cause my low stall speeds?
Old Jul 12, 2006 | 01:03 PM
  #44
Roarin_8's Avatar
Check your brakes.
Old Jul 12, 2006 | 07:11 PM
  #45
camkid's Avatar
well so i finally came to the conclusion that its slower to preload the stock conv. if i just anticipate the light and dump the pedal from an idle i get a faster jump then brake standing it. i tried over and over, but now have to change my brakes if i brake it the car spins through first rather than when i dump it it spins until about 3000 rpm's anyone disagree?
Old Jul 12, 2006 | 07:22 PM
  #46
camkid's Avatar
ohhh and what also works well is if you stop at the light and hold the brakes while pumping the pedal three times, it makes use of the triple bypass converter regulator while still preloading the inacuator servo accumulators. if this is done right your electronic engine manifold deffibulator can raise the engine output torque range to about 3500 rpm's. when you dump the pedal the engine component sensor reads well above regular there for it raises the air regulator mass sensor allowing the intake manifold to correct the y-junction interconnect. well all in all it work so DO IT!
Old Jul 12, 2006 | 08:38 PM
  #47
BlackHawk T/A's Avatar
I'll have to try that, as soon as I install that flux capacitor for better flux dispersion banding.
Old Jul 12, 2006 | 08:47 PM
  #48
LS1 Sounds's Avatar
camkid, you come up with some funny ****.
Old Jul 13, 2006 | 01:37 AM
  #49
98hardtopZ's Avatar
Originally Posted by s346k
you rookie, just rev it in N then pull it back into D after you determine what rpm you want to launch at...
my car likes 2,800.
ive always enjoyed 5k....but seriously today i was almost hit goin down the road, and truck came over on me so i hit the brakes and when i did my hand was resting on the shifter and i accidentally put it in neutral so my rev's went up. we ll i changed lanes and wasnt thinking and dropped it into d and broke loose...didnt pop or anything but kinda scared me....i then proceeded to pull up next to the truck and flip the driver off and scream **** you *******...
Old Jul 13, 2006 | 01:21 PM
  #50
lunatik's Avatar
Originally Posted by Roarin_8
I've always wondered what would happen if you would accidently put the car in reverse while you are crusing on the highway. Just wondered, would never do it.
did that in my 68 years ago. the ONLY day I hasnt trying to screw around in it (on my way to get touch up paint). I was entering a entrance ramp to the parkway and throttle stuck. not a problem happend before. instead of just turning it off (wouldnt unstick-just got stuck on the floor after trying) i attended to put it in neutral and turn it off. I missed N and put it in R at 70mph! engine tacked like never before- I didnt know i had it R. started spinning the tires backwards. let me tell you handle a skid with the tires in wrong motion is hard as hell especially at those speeds. great th350 held up. the tire broke loose and left a mark the KSP had to measure with his odeometer-just shy of 660ft! after an 1/8th mile the car ran off the road and slammed into the ditch flipping me around. hard hit! had rubber all over the doors. that was 1999 and i still gotta see a chiropractor. sorry for the long post just had to warn anybody thinking about it.
Old Jul 13, 2006 | 01:47 PM
  #51
00'WS6Rocket's Avatar
Thanks for the info guys i just destroyed my tranny !!!!!!!
j/k but i do have a question If you have a 3500 stall, and you just step on it without/brake stall etc. are you still gonna roast the tires?
Old Jul 13, 2006 | 02:03 PM
  #52
LS1 Sounds's Avatar
Probably even worse than if you brake-stalled it up to preload the suspension/chassis.
Old Sep 7, 2006 | 07:51 AM
  #53
camkid's Avatar
well all in all im very confused and my tranny has fallen out of my car, i broke up with my girlfriend, my pants are ripped and i just threw up
Old Sep 7, 2006 | 07:52 AM
  #54
camkid's Avatar
and farted one of those farts where its moist and you get butt spray on your undies
Old Sep 7, 2006 | 08:10 AM
  #55
Roarin_8's Avatar
That's not a fart, that's a shart.
Old Sep 7, 2006 | 09:35 AM
  #56
camkid's Avatar
Shart, Fart All In All I Shat
Old Sep 7, 2006 | 09:53 AM
  #57
camkid's Avatar
or a swap mister
Old Sep 7, 2006 | 10:47 AM
  #58
-Freak-'s Avatar
use to do that with my slant 6 75 dodge dart. i tried everything to kill it and couldn't.
55-60mph reverse drops, sometimes the vehicle would just die others it would grab and i'd leave one wheel wonder marks for a few hundred feet . aaahhh the good ol days.
Old Sep 7, 2006 | 11:37 AM
  #59
JL ws-6's Avatar
Race your car!
That made me laugh, thanks.
Old Sep 7, 2006 | 01:03 PM
  #60
-Freak-'s Avatar
those slant 6's were built like tanks, and could take damn near anything. hell i ran it up to 110mph in 3rd gear once. was shaking a bit until i shifted it into D and then it smoothed out. was my first car and got no respect, now i wish i had it back so i could put my 383cid in it.
for launching i'd hold tighten everything up till just before your tires start to break loose then let it fly.
