4k stall or 4.10s...or both?
Old Jul 10, 2006 | 12:35 AM
SVT THIS's Avatar
Most will say 3500-3800. I'll say 4000-4400. I think if you get a 3500 stall you will kick yourself in the *** for not getting a 4000. If I got a 4000 I would kick myself in the *** for not getting a 4400. It's up to you. 4400 is entirely streetable on my (currently) untuned, stock cammed, 2.73 geared car and hasn't been touched by anyone yet. Once I get in a cam and a set of 4.10s to tighten it up it'll rock the **** out every road it touches. Don't listen to anybody who says that 4000+ is to much for the stock LS1 cam, biggest load of **** you've ever been told....they are probably running a 3200 stall in their weekend LS1 and driving a Plymouth Voyager to soccer games
Old Jul 10, 2006 | 01:02 AM
TV559's Avatar
Just keep the 3.23 gears you have now and put a 4000 Stall in.
Old Jul 10, 2006 | 02:02 PM
cha1nz1535's Avatar
yeah i think im going to go with the 4000 ne input on brand or does it not matter?
Old Jul 10, 2006 | 02:13 PM
monicaz28's Avatar
Brand DEFINITELY matters. There are a lot of good companies out there, the two that I really like are TCI and Yank, not to downplay the others. It's just that I've had good experiences with those two companies.
Old Jul 10, 2006 | 02:17 PM
Honda Hunter's Avatar
Most peoples opinions will be biased. I dont even know if there really is a best. Ive delt with Yank and over all I was happy with the service.
Old Jul 10, 2006 | 02:34 PM
monicaz28's Avatar
I agree, a lot of it is opinion. I have a Yank tc, but one of my friends switched from a Yank to a TCI and it hit a lot harder off the line than the Yank ever did.
Old Jul 10, 2006 | 02:58 PM
s346k's Avatar
since you have 323s, i vote stepping up to a 4400 stall. i have a 4k stall and 373s, and now i wish i had gone 4400+. i ran the time in sig with the 4k stall, 373 gears, headers, ls6 intake, and lid. stock engine tune, tranny was tuned for the stall. (shift points and tqm removed)
if you plan on spraying that thing, stick with a gear numerically lower or equal to 3.73, as you will be shifting into OD in the 1/4 on the bottle otherwise. this is why i went with 3.73s, after my cam install i will only have a 7,200 rpm rev limiter to play with and i'd like to stick with 26" tall tires.
oh, and...i cut low 1.6x 60' at the track spinning on bfg DRs - i just got some m/t drag radials (255/50/16) and they hook on the street with 25 psi like my bfgs did at the track with 14 psi. moral of the story: get some m/t drag radials to hook on the street. my susp. consists of kb sub frames, spohn lcas, and removed front swaybar.
Old Jul 10, 2006 | 11:41 PM
01_ram-air's Avatar
I have 3.23s. I went 13.5s stock on street tires. I added ET streets and a Yank 4000 and dropped to 12.5s. Keeping everything else the same. So, my opinion would be to add a 4000 stall. Yank, Vig, fuddle in that order IMO. I daily drive my car too. If you plan on spraying it I wouldn't go larger than 4000 IMO. If you plan on staying N/A, no problem with a 4400
Old Jul 11, 2006 | 03:12 PM
cha1nz1535's Avatar
wheres a store or place i can buy the 4000 yank for cheap
Old Jul 11, 2006 | 03:21 PM
s346k's Avatar
ls1tech for sale section.
yank and cheap go together like oil and water.
Old Jul 11, 2006 | 07:32 PM
cha1nz1535's Avatar
haha not good
Old Jul 14, 2006 | 10:40 PM
  #32
cha1nz1535's Avatar
Another question...What else am i going to need to get if i buy a 4k stall? Will i need a tranny cooler? Also how much is install?
Old Jul 14, 2006 | 11:54 PM
  #33
MESS's Avatar
like the title says.
I just wanna beat the cocky sob down the street in a race
This is so true for all of us..... This is why I mod!
Old Jul 15, 2006 | 12:07 PM
  #34
stripes1987's Avatar
you are deffinatly gonna need a tranny cooler and make sure it is a good size one and also a tranny temp gauge and that should be it on mine i run two big coolers and one with a fan on it and let me say that fan can pull some damn heat!!! the tranny down in florida around noon with a heat index of 105 the tranny only hits maybe 195 but thats down in florida if you live up north where it doesnt get that hot one cooler will be plenty
Old Jul 15, 2006 | 01:10 PM
  #35
cha1nz1535's Avatar
so how much $$$ is this going to run me in all?
Old Jul 15, 2006 | 08:11 PM
  #36
SVT THIS's Avatar
I spent $400 on the stall from Fuddle. About $100 on the cooler from LS1speed.com, and I paid a member of the local Fbody club around $200 for the install. Most shops I called charged around $300-400 for the install. You will also need your tranny lines flushed which will run another $125 or so. Definately worth it.
Old Jul 15, 2006 | 08:37 PM
  #37
Scotty-Z's Avatar
4000 stall first.
Then 3.73s if you feel you still need some more.
Old Aug 19, 2006 | 05:15 PM
  #38
1nicet/a98's Avatar
Ur betta off going with the TC, but both wouldnt be to bad either
