Question on code P0757 Shift Solenoid B Stuck On
Old Jul 8, 2006 | 11:15 AM
killerinyou's Avatar
Default Question on code P0757 Shift Solenoid B Stuck On
I've got an '01 TA WS6, the SES light came on a couple days ago, so today I used a friends scanner and got the following:
I don't know a lot about engines, so I was hoping that someone could tell me how serious of a message this is. The car starts up fine every time without any problems. Also, what would have to be done to fix this. Any info would be greatly appreciated. Car is an A4 no stall converter installed.
Old Jul 8, 2006 | 04:42 PM
FLT's Avatar
FLT
Sounds like possiably it is time to put some new shift solenoids in your trans.
Old Jul 8, 2006 | 10:26 PM
AK's WS6's Avatar
I got a similar code after I put my stall in, but it shifts just fine so I didn't really do anything about it. It's common after you put a stall in, but in your case it might be an issue since you haven't done anything to the car.
Old Jul 8, 2006 | 11:13 PM
Thanks for the info guys. Any idea how much a trans shop is going to charge me to replace the Solenoids.
Old Jul 9, 2006 | 04:25 PM
Pewterpower's Avatar
If you know how to change your fluid and filter, then you can change the solenoid. It's in the same place. The only tool you need is a needle nose pliers, and the solenoid is only about $25.
