Racing tips - PLEASE! - ST3500...
Old May 26, 2002 | 10:25 AM
INSSANE's Avatar
Default Racing tips - PLEASE! - ST3500...
Last time at the track, with BFG DRs, the best I could get was 13.0ish at mid to high 1.9s. The track just sucked. I may begoing back tommorrow, so do you have any suggestions?
IE - psi, launching, waterbox, RPMs, etc...
I should really be sing 12.6xx, but I'm not. And I should really be seeing 1.6s and I'm not. Others have major problems hooking with this track too, but it's close.
Thanks
Nick
Old May 26, 2002 | 01:01 PM
INSSANE's Avatar
Default Re: Racing tips - PLEASE! - ST3500...
But see my sig as to what's going in soon...
What mods do you have?
Old May 26, 2002 | 01:21 PM
Supertrapped's Avatar
Speed freak
FTRA, lid, MAF ends, MAC headers, x-pipe system, ST3500, ET Streets. Still runnin on stock 2:73 gearing too.
<small>[ May 26, 2002, 05:29 PM: Message edited by: DevilBird ]</small>
Old May 26, 2002 | 07:47 PM
Ragtop 99's Avatar
When I was bolt-on, I had st3500/3.23s/nittos. I used 16 - 20 lbs depending on track prep. I heated the **** out of them, making sure I could see smoke in my rear view mirror.
My best 60' times came from punching it at 800 - 900 rpm. If I hooked, the run would be excellent. For brackets, I would stall to 2000 rpm and roll hard into the throttle. Greatly reduce the risk of spinning, but the 60' lost about .05.
Old May 27, 2002 | 12:11 AM
Speed freak
First off...get rid of those BFGs and throw on some ET Streets with that converter. I've got a ST3500 and could never really launch good with BFGs.
But for now, with you runnin DR's, I'd drop the pressure to 15-18psi. Back up into the waterbox, spin foward to get the water off, then lay into and do a little smokey burnout.
Now...as far as launching...play with it a little. Launch at idle, bring the rpms up to 1500 the next time out, then bring the rpms up to 2500 the next time out, and so on. Learn what feels good and whats comfortable to you. Everybody and every car is different.
Old May 27, 2002 | 12:16 AM
INSSANE's Avatar
Did the waterbox thing. Smoked them for 10 seconds, tried different RPMs and launching techniques. I don't wanna screw my rear end up w/ ETs yet.
I'm just making sure I'm doing everything right.
Nick
Old May 27, 2002 | 12:51 AM
Speed freak
I've been racing on stock rear with ETs for over a year now. Haven't had any problems <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
