cooler with converter? and lockup questions
i also just got ls1edit, can i do anything i want with the converter lockup? could i hurt anything? i am thinking about makeing it lock up alot more of the time. it wont lock up untill i get into 3rd, it seems like in city trafic the truck should be locked up sooner.
<small>[ May 30, 2002, 11:28 PM: Message edited by: parish8 ]</small>
You can lower your 3rd gear lock-up speed using Edit. I would not lock the converter in 2nd gear, although at very low throttle levels it would probably be ok.
