vacuum mod or not?
Does it hit hard at 230 psi pressure? Yes!! Are you at this pressure constantly??? No!!! Remember it is not high pressure you have to worry about its low pressure....low pressure kills transmissions. High pressure has its own set of rules (which in this Trans really limit it) Can you have hard garage shifts with high pressure??? Yes!!
Generally speaking my guys would rather hard garage shifts than soft hi rev shifts ... wouldn't you rather have high pressure shifts?? (Even post Elvis tuners tune for higher pressure). Our typical Low pressure is 90 psi at 14 inches of vacuum. My customers complain at 110 psi which is my preference, but hey who wants to argue?? I’ll compromise. It’s a win, win my line of thinking is 110 is closer to 230 than 90 is so it’s got to build faster …seems logical… suffice it to say 90 psi works well. John you can chime in any time you want, yours is 110 does it have a bad garage shift to it??(Sorry I missed you the other day)
So let’s review…Zero inches of vacuum equals 230 psi MAX line pressure. 14 inches. Of vacuum equals 90 psi MIN line pressure. So there’s your max and min, go install your cams…have fun, I can’t spell vacuum so if I’ve misspelled it forgive me I’m in a hurry. Hope this helps…. Dave
thanks Rock-On and PBA. you've really helped me understand vacuum modulation. you can be as sure as the sky is blue that my next tranny (if my stocker ever goes...and i hope it doesn't) will have the vacuum mod.
Bryan
I now have a little 214* cam and I still have the hot air @ idle.
As for shifting... It is great, especially @ WOT... I love the tire bark on the 1-2.
thanks,
bryan
Pre-vacuum modulated tranny I saw two occasions of complete slip on the 1-2 shift. Both times were when I had issues with my new header install and a plug wire getting onto the header and burning. Didn't know what was going on until developed a dead miss. The second time I had a slip I went straight to the plug wire. It had burnt enough to arc to the header but not missing yet. I feel that the spark voltage (noise) getting to the engine upset the ECM line pressure control.
Bryan
