burnout question
Old Jul 24, 2006 | 07:39 PM
Charlie Hustle's Avatar
Default burnout question
whats the best gear to have it in while you do a burnout and why? ive usually just left it in drive. but ive been reading about people putting it in 2nd or 3rd. i have a 2001 a4 ws6 with a vig 3200 stall. thanks in advance
Old Jul 24, 2006 | 09:21 PM
kruthes1's Avatar
I start in 1'st to get it going then put it in 2nd and hold it at about 4500 for a few seconds.
Old Jul 25, 2006 | 09:10 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
What he said
Old Jul 25, 2006 | 11:01 AM
WhiteKnight98TA's Avatar
Good question - i've been wondering the same thing.
my first outing to the track was a bit embarrising at the car's attempted burn out.
(this is my frist auto)
My friend with a 98 Z just leaves his in D and nails the gas - but he also has a 408 in there so....
Old Jul 25, 2006 | 04:04 PM
SLP 02 SS's Avatar
Put the car in 3rd gear and leave it there while your going down the track.
Does fine with your burnouts. You don't really want to have the car in "D"
because that will activate your OD...Not a good thing. It actually cuts down
your ET because it drops your RPM so much. You want to keep your RPM up.
Oh Yeah,....if so equipped...Turn Off the Traction Control.
Enjoy
Old Jul 25, 2006 | 04:07 PM
Predator T/A's Avatar
well when you are in manual it raises the line pressure and it also applies the overun clutches to give more holding power so its best to have it in manual range.
Old Jul 25, 2006 | 04:11 PM
furthermore for tranny longgevity i wouldnt burn into second because that puts alot of stress on your 2-4 band
Old Jul 25, 2006 | 05:15 PM
Enjoy
how much time are we talking about, between leaving it in drive, or 3rd?
Old Jul 25, 2006 | 05:46 PM
i doubt very seriously that you will shift into 4th under wot in the 1/4 mile i know mine has never done it but again leave it in 3 for drag racing you will have more clutches applied becuase the overun clutches will come on in manual 3 and 2 and 1 where they normally only come on on decel to give engine braking also the line pressure will be higher
