3200 vs 3600 yenk
thanks guys
if you are thinking 32 or 3600 then what you really want is a 4000. you will be sorry you didnt go bigger. i went with the yank ss3600 and wonder why the hell i didnt go 4000 or even 4400 Trending Topics
now running Th400 with 4K stall
get the 3600 (dont forget the transcooler, delete TM, and shift kit) and never look back
So...Take it or leave it.
You said that you're mostly going to be Daily Driving with a Stock Tranny.
So more than likely your rearend is Stock too Right?
The Yanks are better at Larger Stall Speeds for the Track.
While the Vigilanti Mid Range Stall Converters 2800-3600rpm are better suited
for the Street/Strip application and won't be so hard on your Rearend either.
I had consistant results of 1.58-1.60 60fts at the track with the Vig.3200
Definitely, do NOT forget the External Oil Cooler. B&M just came out with a
cooler that takes A.N. Fittings instead of Regular hose connection. I would
strongly advise the use of this cooler with the Steel Braided Lines.
Save yourself a big Headache later on down the road.
If you haven't already installed a Shift Kit... DO SO.
"Trans Go" makes about the best for the 4th Gens. You can install it several
different ways to accommidate for your specific needs.
Well, like I said...Take it or Leave it.
Have Fun and Be Safe
I currently run a YANK SS4000Extreme Converter
BUT.......
I also have a Moser 9" w/ 3.70 Posi "Straight Cut" gears and a FLT "Level 5"
Tranny now. Not to Mention a Custom 3" Drive Shaft with 1350 Yokes.
Ed
really appreciate it
thanks
