Quick A4 question
Old Jun 8, 2002 | 10:23 PM
Billy C's Avatar
Default Quick A4 question
Hey guys , As some of you may know , I have done a M6 to A4 swap in my 99 Z , Well I sent my computer to get programed and in the meantime I borrowed a friends computer out of his 02 Z , Heres the problem , If I put the car in "D" , It only takes off in second , If I put the car in "OD" , it seems to shift fine through all gears , I can manualy shift 1st to 2nd , but cant go to "drive" unless I pop it all the way to "OD" Also , my sy3500 converter is not locking up ??? I have checked my wiring a couple of times and It seems ok , could it be in his computer ? Or in the tranny ? thanks !!!
<small>[ June 08, 2002, 10:26 PM: Message edited by: Billy C ]</small>
Old Jun 9, 2002 | 04:44 PM
Billy C's Avatar
Default Re: Quick A4 question
ttt
Old Jun 10, 2002 | 07:42 AM
msce2b-dustin's Avatar
Billy...I'll go out on a limb here since no one else has and suggest it is the pcm. The 00 and later a4's have the option of second gear start up. Sounds like that what yours is doing. The pcm ares defilantly different between 99 and 02 and I would suggest getting the correct pcm before you try anything else.
Old Jun 10, 2002 | 03:02 PM
Billy C's Avatar
cool Dustin , Someone else told me that also ! I will get my PCM back from Ed Wright tommorw , so that is a good thing !!!!! BTW , whats all this "giving up racing" crap , You know once it's in your system you can never get it out !!!
