What MPH should 3rd gear take me to?
Old Aug 15, 2006 | 10:06 PM
SSPEEDY's Avatar
Originally Posted by 02 BLK WS6
3.23 were a performance option for Z28, T/A, and Firebirds. Standard on SS and WS6.
The 3.23 option also gave folks an aluminum driveshaft. The 2.73 geared A4's received a steel shaft.
Old Aug 15, 2006 | 10:12 PM
SSPEEDY's Avatar
Originally Posted by BlackHawk T/A
Also there is no way a 3.23 gear will run you that high. My car is also a stock 3.23 car and it will want to go into OD around 120.
Cars with an aftermarket stall will run out quicker because of slippage. With a stock converter you could carry out 3rd at a higher mph. An aftermarket stall will bring it down.
When i had the stock converter I'd hit 130+ in 3rd, now it's just over 120 with a higher rpm limit.
Keeping it in 3rd to see the limits and when you top out.
