Oil Pump Removal
Old Aug 10, 2006 | 03:52 PM
Red_Dragon's Avatar
Default Oil Pump Removal
I have a 700R4(4L60) trans out of my truck and I am having trouble getting the oil pump out. I thought you guys would probably be able to help since my trans is just older with no electronics pretty much. I have the filter and selonoid out along with like all 6 bolts or so on the pump. I have tried making my own ways to pull the pump out, but can't get it. Is it just stuck or did I miss something? Thanx for any help.
Old Aug 10, 2006 | 10:32 PM
Red_Dragon's Avatar
Well I ended up getting the pump out. I crushed a U-bolt to fit tight around the shaft and the pump came out pretty easy with a puller.
Old Aug 10, 2006 | 11:55 PM
pcs9449's Avatar
Worse case scenario you could have used a pry bar against the reverse/input housing and the pump half, just need to be careful not to pry too hard
Sean
