3 Pumps Broken
Old Aug 11, 2006 | 05:06 AM
Npak's Avatar
Default 3 Pumps Broken
how the hell am i breaking 3 different tranny pumps. i had all 3 splines aligned and when bolted the bell housing down i broke the ******* pump!
Old Aug 11, 2006 | 09:15 AM
spy2520's Avatar
if the converter isnt atleast an inch within the bellhousing you probably will break the pump each time when bolting it down...
Old Aug 11, 2006 | 05:34 PM
Npak's Avatar
ii had less than half an inch wehn it was seated properly and still some how i fucked up.
Old Aug 11, 2006 | 06:09 PM
Predator T/A's Avatar
did you put the pump together you may have the rotor in the wrong way
Old Aug 12, 2006 | 11:04 AM
Npak's Avatar
tranny mechanic installed the pump. i broke it w/ two decently loud pops when putting on the bellhousing. im a dumbass and should ahve gone a bit slower.
Old Aug 12, 2006 | 11:43 AM
the converter should go in three times and there should be a little bit of a gap from ther flywheel to the converter
