hitting nuetral at 5000rpm???
Old Aug 21, 2006 | 02:06 PM
phildo's Avatar
Default hitting nuetral at 5000rpm???
When I am in drive and floor it the trans stalls up, starts to pull, then just free revs like I hit neutral. If I manually select 2nd and floor it it seems to pull fine. What is the deal? I know I am over powering it ( cam heads sts turbo) but it seems like it gets confused. I have double checked my trans charts and they look good. Is she on her way out?
Old Aug 21, 2006 | 03:35 PM
ChocoTaco369's Avatar
Tech Resident
sounds like your trans is slipping. you likely burnt a clutch up. sounds like it's nearing time for a rebuild
do you have an aftermarket stall? do you have any mods? a mod list and a better description of the problem will help.
