Question regarding stall and gearing..
Old Jun 18, 2002 | 11:05 PM
JS's Avatar
JS
Default Question regarding stall and gearing..
Say u had a converter built for a setup thats running a 4.10/26in tire combo.
Then u go to a 4.56/28in combo.
Will this effect the flash,stall or shift extension of the verter?
JS
Old Jun 19, 2002 | 08:49 AM
Ragtop 99's Avatar
Default Re: Question regarding stall and gearing..
Assuming the effective gearing is about the same (i.e. resulting rpm/mph is equal), the effect, if any, will be very minimal.
Old Jun 19, 2002 | 08:55 AM
CHRISPY's Avatar
You will notice very little change at the track cause the overall final drive is very close.
However on the street if you are running a 26 inch tire you will notice the converter feel a little tighter around town
Cheers,
Chris
