Anyone running Hughes TH350 flexplate/pilot adapter?
Old 08-28-2006, 09:34 PM
Crawlin Z's Avatar
Default Anyone running Hughes TH350 flexplate/pilot adapter?
I'm thinking of running these w/ a TCI converter, any feedback would be appreciated. Thanks-Nick
Old 08-30-2006, 10:54 PM
TJ
TJ's Avatar
do you have a std small block converter, or was it built around the ls1 platform?
if you have the long hub on your converter, id double check to make sure you need it.
Old 08-31-2006, 12:46 AM
Crawlin Z's Avatar
conventional TH350 converter
Old 08-31-2006, 06:24 PM
TJ
TJ's Avatar
i run a GM spacer with my th350 converter. im sure the hughes works the same.
good luck.
Quick Reply: Anyone running Hughes TH350 flexplate/pilot adapter?
