torque converter problems
Old Aug 31, 2006 | 08:14 AM
chevygirl's Avatar
The mechanic told me the trans. has to be removed and that is what the book shows they charge.
Old Aug 31, 2006 | 12:17 PM
C5XTASY's Avatar
Six hours sounds pretty close to a C5 Corvette converter chanegout. I thought F-bodies were quite a bit less than that. I could be wrong though. Good luck to you. I guess that, personally, I would have moved on to a different shop. I have heard of converters being out of balance and causing issues. I read somewhere that engines are sometimes balanced at the factory with the converter in place, and, if removed, and not reinstalled in the exact same mounting relationship, vibration can occur. Whethr that would seem like a rough idle or not, I'm not sure. I'd give someone else a crack at the car. I'd find a high performance shop. I think the first place has had their shot. Sometimes a fresh approach, and fresh minds, does wonders. Good luck to you!
Ed
Old Aug 31, 2006 | 01:14 PM
chevygirl's Avatar
They are actually the 4th place I have taken it to. These guys say they want to make sure I am completely happy with their work. We do not have alot to choose from here in memphis. We do not have high performance shops. Everything is stock so I would think a certifed GM tech would be able to figure it out. I appreciate all of your help. I will let you know what I find out.
Old Aug 31, 2006 | 01:28 PM
Roarin_8's Avatar
Everything is stock?! How many miles on the car?
Old Aug 31, 2006 | 01:50 PM
tinytimsolderbrother's Avatar
Default hes not too far off
mitchell on deman shows 4.8 hours
so hes not too far off
most people charge around 250 -300 to swap a converter
but here in oklahoma city you can get the trans overhauled
for around 500-700 in labor depending where yah go
Old Aug 31, 2006 | 05:18 PM
chevygirl's Avatar
Everything is stock except for cat and exhaust.
Old Aug 31, 2006 | 06:00 PM
Roarin_8's Avatar
If it's running rough at idle, what's the A/F look like? Maybe you have a bad 02 sensor. Try the simple things first. Pulling the converter should be the last thing you do.
Old Aug 31, 2006 | 10:59 PM
ChocoTaco369's Avatar
Tech Resident
i'm with roarin_8. ever try cleaning off your MAF and IAC sensor? they may simply be dirty. maybe you need new plugs and wires. or, you could try seafoaming your car i didn't know you were nearly bone stock. now i bet you're in need of simple maintenance.
Old Sep 1, 2006 | 07:55 AM
chevygirl's Avatar
All of the items named have been replaced. Every ignition part and all sensors. We swapped things out trying to fix it but never got fixed. I know it should be the last option. No one seems to know what is wrong with it.
Old Sep 1, 2006 | 09:26 AM
Roarin_8's Avatar
Seems like it's time to take out the converter, could get an aftermarket one while you are in there
Old Sep 1, 2006 | 10:09 AM
sickws698's Avatar
mite be a cam or a tune problem
Old Sep 1, 2006 | 10:17 AM
  #32
Roarin_8's Avatar
She's switched the whole motor, cam included I'm guessing. Asked her about tune (A/F) in post 27. Seems like this is the last option.
Old Sep 1, 2006 | 11:15 AM
  #33
chevygirl's Avatar
It is not the motor. Last 2 new engines do the same thing. What do you mean by tune? I am wanting to keep everything stock because I didn't want any excuses on why it would not run right. The car may be missing is all but why is it missing and why is it not doing it all the time. It feels like no power and the car won't go when cruising along and giving it gas gradually-just shakes and vibrates.
Old Sep 1, 2006 | 11:20 AM
  #34
Roarin_8's Avatar
Change the converter since it gives you problems driving as well, thought it was just at idle, that may be the culprit.
Old Sep 1, 2006 | 07:17 PM
  #35
chevygirl's Avatar
Okay I have a question. I drove it in drive instead of overdrive and got it up to 60. It did not seem to vibrate as bad or not at all. It starts shaking between 45 and up close to 50 in overdrive. Do you think my tcc solenoid might not be working?
