TH400 questions please help.
Things I know so far
TH400 tranny
TH400 crossmember whats everyone think of the BMR?
shifter
Custom drive shaft (I have a 9" what drive shaft do i need?)
Thanks
Sean
1. TH400 tranny with 2.75 first gear, reverse manual valve body, transbrake $1480 from a local shop
2. BMR Crossmember $50 dollars. (My car was the prototype that brett made the crossmember with so I got it for cheap <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
3. JW 4500 stall converter $460
4. B&M Hammer shifter $200
5. TCI Transmission cooler 15 1/2" X 10" X 3/4" $65 from jegs
6. Driveshaft I have right now is off a friends car he had a TH400 and a ford 9" and had the driveshaft made at a local shop and I bought the 9" and the driveshaft from him. I'm buying a new one from Dennys very soon as this one I have no is out of balance and has a bad vibration. Dennys nitrous driveshafts are around $350
My tranny bolts directly to the block and uses all the bolts on the TH400 but one. With the JW converter I got I did need to have a crank pilot extension made to keep proper converter -> flexplate spacing. If you have headers or plan to put them on in the future you will need to cut the "ears" off the sides of the TH400 casing to get it to fit up in there. If you're swapping from an A4 to a TH400 you will need two other things. I would get a center console out of a 6-speed car because I was able to get the b&m shifter to fit in there without cutting it at all. You need to cut the hell out of the A4 console to get a shifter to fit. The other thing is you will need computer programming to delete the A4 tranny controls in the computer. That's al I can thing of that I bought for right now if I remember anything else I'll post
L8r
Will
<strong>If you're swapping from an A4 to a TH400 you will need two other things. I would get a center console out of a 6-speed car because I was able to get the b&m shifter to fit in there without cutting it at all. You need to cut the hell out of the A4 console to get a shifter to fit.
Will</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why not just use the stock shifter? I have heard that it will fit with no problems. Trevor D had his stock shifter with a TH400.
The only problem I have is that I have a GW Trac Link. NO crossmember out there will fit. I think I will just fab one up.
Tim
Tim
<strong>you CAN use the stock shifter but in my opinion it's a pain in the ***. Two reasons, One is that you have to fab a bracket to get it to even work so it mounts to the tranny.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Trevor told me his fit right on with no modifications. We'll see.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MacGyver:
<strong>Second is that in order to shift from 1st gear (with reverse valve body) to second gear you have to push in the button on top (or the side for a T/A) of the shifter which leads to many missed shifts where you go from 1st all the way to third because there is no stop at all between the gears once you're out of first.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I went with the forward valve body. My wife drives it every now and then when I start doin **** to her car, so I don't need her freakin out in traffic tryin to shift. LOL
Now, I do know that the 1st gear position is gone on the shifter. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tim
