Tranny cooler? In series or seperate from stock cooler?
Old Jun 22, 2002 | 09:53 PM
PHIL H's Avatar
Default Tranny cooler? In series or seperate from stock cooler?
Getting ready to install my new TP4400. I think I will get the B&M 19,000. Is everyone running it seperate from the stock cooler in the rad or running it through both? Mounting pics would be nice also. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Phil
Old Jun 23, 2002 | 12:44 AM
TomQ's Avatar
Default Re: Tranny cooler? In series or seperate from stock cooler?
running through both...
i think it's even better to have 2 coolers then one, don't u think <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 23, 2002 | 07:33 AM
OBSSSD's Avatar
Get the 24,000 B&M cooler. Run the cooler AFTER you go through the radiatior on the return line to the trans. You'll also need a deep pan with fins. I'd recommend the TCI or B&M from JEGS.COM
<small>[ June 23, 2002, 07:35 AM: Message edited by: OBSSSD ]</small>
Old Jun 23, 2002 | 07:49 AM
Ragtop 99's Avatar
In series; after the oil goes through the stock cooler. The combination of a 160 T-stat and cooler keep my temps low.
OBSSSD's suggestions are a very good idea if you plan to auto-x.
Old Jun 23, 2002 | 08:54 PM
OBSSSD's Avatar
Ragtop, they are also good if you live where it's 100+ several months out of the year <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jun 23, 2002 | 10:09 PM
PHIL H's Avatar
So is the bottom line the supply and the top return?
Old Jun 27, 2002 | 08:50 PM
PHIL H's Avatar
which is return and which is supply????? Ragtop????? Also where does everyone mount their cooler?
Old Jun 28, 2002 | 12:04 AM
highgear's Avatar
Top line is the return.
Get at least a 22-24,000GVW cooler.
Most people mount it in front of the Condenser.
Whatever brand you get; make sure it has instructions,parts, etc. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Jun 28, 2002 | 12:10 AM
horist's Avatar
Are there any advantages to using the cooler as a standalone device? That's the way mine's hooked up but I'm going to switch to a bigger cooler soon... not sure about inline/series w/stock radiator though
Old Jun 28, 2002 | 07:27 AM
OBSSSD's Avatar
If you bypass the stock cooler you are losing cooling and capacity in your system, especially if you are running a cooler t-stat..
Old Jun 30, 2002 | 01:29 AM
MMI Z28's Avatar
the return it on the top?
