heads and cam on auto?
Ed
Also, be easy on it on the 2-3, 3-4, and 4-3 shifts. the 3-4 band is likely the first to go. On my cam only caprice, the previous owner killed 3rd(and 4th) gear in about a year on a used trans. even with a shift kit and a tuned computer(pretty sure the line pressure was uped a bit via PCM). so don't count on it lasting.
The only problem with this is, your overrun clutches come on and your TCC will lock back up in 3rd gear. When you do floor it, the transmission will not respond immediately and it will take a second to unlock the converter and downshift. It will feel like 2 downshifts. It is something I am going to fix with tuning (hopefully) by disabling TCC lockup in the 3 selection, if possible.
