straight cut planet gears vs helical
the thing with straight cut teeth is the thrust load. We do alot of powerglides for dragster and near 600-700 hp we find the ring gear thrust rearward and rub on the pressure plate for the reverse pack. with a straight cut gearset not even our customers that run 6's have any problems. the only way that a straight would be faster is due to the fact that you could run a smaller lighter gear with equal strength, becuase with a helical cut tooth you have more contact on hte tooth. the only advantage to a helical cut is that it doesn't make any noise. next time you hear an allison 1000 take off that cat meowing sound is due to the straight gears.
