Vigilante and Nitrious Question?
Old Sep 25, 2006 | 05:52 PM
J'sRedWS6's Avatar
Default Vigilante and Nitrious Question?
Im leaning towards a 3200stall vigilante, but heard the vig robs more horsepower to the wheels than other converters like yank anybody know if thats true. Im also thinking of a 100 or 125 shot of nitrious, guy at thunder said car can handle it, What do you guys think.Right now mods are LTpacesetters and ORY,LS6,portTB,K/N FIPKand Corsa cat. best run so far was a 13.2.I will be getting a Dyno Tune after the Stall and Trans GO kit. Any information would be appreciated.
Old Sep 25, 2006 | 07:21 PM
Dbluegoat's Avatar
before my vig 3200 i dyno'd at 472 after 440
I went from 11.93 to 11.53 and from 1.81 to a 1.51
Old Sep 25, 2006 | 08:28 PM
gator's 99TA's Avatar
vig 3200 LOVES the nitrous.
Old Sep 26, 2006 | 03:34 PM
Gold Z's Avatar
Vig 3200 is the best converter I have found and I've gone through about a dozen different brands and stall speeds. Get it, you will never regret it.
Old Sep 26, 2006 | 05:56 PM
1ORANGEWS6's Avatar
I run a 7.17 w 1.50 60' in the 1/8th with mac mids, Vig 3200, auburn pro posi, ET DRs, and 100 shot. I loved that converter it was bad *** from a dig. I haven't had a chance to run my multi-disc 3600 at the track yet but it's a little loose on the street.
Old Sep 26, 2006 | 05:58 PM
1ImperialSS's Avatar
formerly silverbrick (changed 02/17/2013)
dont worry about dyno numbers. as long as it hauls ***** at the track, people with higher numbers will eat their words. would you rather have your car dyno 480 at the wheels, then when you take it to the track, first shot of nitrous and you slip up to the rev limiter and blow up, or dyno 450 and skull drag the guy next to you with more power?
Old Sep 27, 2006 | 02:47 AM
ss4chad's Avatar
Skull Drag?
Old Sep 27, 2006 | 06:40 AM
must be an expression from the PT affiliate...
Old Sep 28, 2006 | 04:27 PM
J'sRedWS6's Avatar
Thanks guys I am getting the Vigilante with the trans go for sure with a tune around the same time.Im not to worried about dyno numbers I know the auto is gonna dyno less than the 6speed.Im still alittle hesitant on the nitrious.More than like will go for it though been looking at the ZEX wet 100-125shot.Just need to do alittle more research before I go with the nitrious
Old Sep 28, 2006 | 08:35 PM
1ORANGEWS6's Avatar
Use the search as much as possible it's your friend in giving you all the info you want.
Old Sep 28, 2006 | 08:58 PM
i think you shoudl stay away from Zex nitrous systems. they are probably the most straight forward and easy kits for beginners but are by far not the best.
