How hard is it to install a converter?
Old Jul 2, 2002 | 08:11 PM
LWL1's Avatar
Default How hard is it to install a converter?
I just bought a vig 2800 and would like to save the money. Is there anything special I need to know about installing this converter? Will I need a trans cooler with this converter? Should I use a shift kit with this converter? What tools will I need? What would be a guesstimate on the time required to do this job? The convertir is used, do I still need to do a break in? I know this is alot of question and I appriciate all of you help in advance.
Thanks, Larry
Old Jul 2, 2002 | 09:09 PM
JNorris's Avatar
Moderator
Default Re: How hard is it to install a converter?
Check out the link below.
Torque converter install
This is the guide I used to install my Vig2800. I installed a cooler and it keeps my trans temps below 180 even at the track in 95-degree heat. The shift kit is a matter of personal preference. Your shifts will be softer with the new converter. I like crisp shifts so I had one installed.
Transmission Jack link
John
