th350-400 guys help inside!
Old Oct 4, 2006 | 12:58 PM
mooreperformance's Avatar
Default th350-400 guys help inside!
I'm installing a th350 with a 6" tailshaft here real soon and I have a few questions...
1.where and what flexplates will work for the sbc torque converters with out shimming?
2. how can I get the speedo to work but still allowing the use of abs? Can I have a tail shaft installed from a 4l60E to keep the torque arm mounting then use a reluctor ring from a 700r4?
Old Oct 4, 2006 | 07:30 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The TCI flexplate will work with a sbc converter because it has a dual bolt pattern. I've been told that there is a company that makes a conversion kit but they didn't know who it was. Trans shops used it when they would which from a 700R4 to a TH350.
Old Oct 4, 2006 | 08:40 PM
will both the 98 and 6.0L flexplates work? Is that with small bolt pattern? Will they need shims? Any one else know about the speedo with functioning abs?
