Tranny or computer gremlins? (shift problems)
Old Oct 19, 2006 | 05:51 PM
needsomeinfo73's Avatar
I don't know if that kit came with an upgraded servo or not? It doesnt mention it in the parts list so maybe its stock?
Originally Posted by BAIN
What gear are you racing in? Have you tried leaving it in OD and see if it still hits the rev limiter? It could be a problem with the overrun gear applied on the 2-3 shift causing a pressure drop going WOT in "D".
I've tried leaving it in OD, D, and manually shifting. happens no matter what.
Old Oct 19, 2006 | 05:55 PM
BAIN's Avatar
Sounds like the clutches may be going then. How many times have you ran it and it hit the rev limiter?
Old Oct 19, 2006 | 06:32 PM
Its been doing this ever since the tranny was freshly rebuilt. Has hit the limiter multiple times under WOT..
Old Oct 19, 2006 | 07:48 PM
performabuilt's Avatar
LS1Tech Sponsor
You could try several different things .
if it dosent allready have it a corvette servo ,sonax servo,superior super servo ,
all of these would decrease your area for 3rd acumulation and may help .
You could go back into the shift kit check everything out enlarge the 3-4 clutch feed ,make sure nothing was blocked that should not have been or drilled that shouldnt have been ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 21, 2006 | 08:44 PM
WeeWolf's Avatar
mine's doing the same thing but i'm thinking the servo is bleeding off under half throttle feels fine but over half throttle feels like it binds a little then shifts. servo issue? if so how long would it take to get one.
Old Oct 22, 2006 | 02:01 AM
usd2sing's Avatar
bump. same 2-3 lag issue
Old Feb 27, 2007 | 09:54 PM
bluecajun5.3's Avatar
11 Second Truck Club
Originally Posted by needsomeinfo73
Well I would agree if it were just reving too high and hitting the rev limiter,, but its like it lets go about 300-400 rpms before it ever even gets close to the rev limiter and then flares up and bounces off of it before shifting to the 3rd. Still sound like the tune?
i'm having that exact same problem on the 2nd to 3rd shift.
1st to 2nd bounces of the rev also. shifts are sloppy at part throttle.
the tune is on point also.
Old Feb 27, 2007 | 10:12 PM
WE TODD DID's Avatar
Originally Posted by PBA
If you are having problems with one of my rebuild kits? Call me, and I will help you out.
You kit is obviously not the problem, its the "rebuilder".
Old Feb 27, 2007 | 10:29 PM
LS1Tech Sponsor
Hopefully PBA and you worked it out I agree it was not the kit but I have said many times to people who ask us about parts there is more to the build than what parts go in thats only half the story
__________________
Call 888-744-6542
Old Feb 28, 2007 | 06:47 AM
WHPLASH's Avatar
Just curious, did they use synthetic trans fluid?
Old Feb 28, 2007 | 05:34 PM
DRIVER456's Avatar
I was going to ask the same thing!..........................Paul
