trans shift hard?
Old Oct 5, 2006 | 06:16 PM
seadoo's Avatar
Default trans shift hard?
my tranny started to shift hard on me the other day.
before the other day, the shifts where crisp not hard.
its a built tranny with a 4K stall.
but now the shifts are hard.
Old Oct 6, 2006 | 12:53 AM
performabuilt's Avatar
LS1Tech Sponsor
Have it scanned soon .
www.performabuilttransmissions.com
Old Oct 6, 2006 | 01:42 AM
staringback05's Avatar
^^^ bingo.....tranny hitting hard=
Old Oct 6, 2006 | 07:56 AM
LS1Tech Sponsor
The Tranny sudenly hitting unussually hard could be several things , from a slipping converter clutch causing 1870 code and high line to a pcs solinod stuck restricted or unhooked though the latter should set a code .
Old Oct 6, 2006 | 08:58 AM
seadoo's Avatar
no codes as of yet.
Old Oct 6, 2006 | 11:25 AM
Camaro ChriSS's Avatar
Likely exactly what is it - it may just be that it hasn't set a hard code yet. It may be pending, but not enough incidences for it to show a DTC yet. I've had this happen - for me it was the 1870.
Old Oct 6, 2006 | 08:34 PM
BlackHawk T/A's Avatar
What if yours does this on the 2-3 shift (part throttle), but you are vacuum modulated? The PCM has no control over line pressure and otherwise the transmission acts normal. It "hits" hard unlike the other gears which still shift nice. The same gear shifts fine at WOT.
