transgo shift kit install help
Old Oct 10, 2006 | 06:47 PM
Chris18927's Avatar
Default transgo shift kit install help
This does look right to me.
(click on pic for bigger shot)
The piston isnt fully seated in and that spring is way up above the mating surface for the 1-2 accumulator housing. I only have 2 spacers in. Is this right?
Old Oct 10, 2006 | 06:56 PM
performabuilt's Avatar
LS1Tech Sponsor
Default spacers and springs
personally I never use more than one spacer , And note that unless thats a 93 transmission it should go like this . spring in first then spacer then piston but turned over from the way you have it ,
performabuilt
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 10, 2006 | 07:08 PM
Chris18927's Avatar
its a 93 transmition, but the spring is supose to be that high up? the picture in the instructions says that it should go: spacers, spring seat, spring, piston, and then it looks like you put another spring on on piston like i have in the picture, is that right or am i trippin'?
Old Oct 10, 2006 | 07:18 PM
FLT's Avatar
FLT
That is the right way to do it even on 93 unit's. Vince
Old Oct 10, 2006 | 07:57 PM
Chris18927's Avatar
that spring on top of the pistons doesnt look like it could possibly be right to me
Old Oct 10, 2006 | 08:22 PM
FLT's Avatar
FLT
It is correct trust me I use this kit every day. It is a little hard to get it bolted to the case but it is correct. How many washers sre you going with? I would start with one and go from there.
Old Oct 10, 2006 | 09:19 PM
Chris18927's Avatar
I have 1 in there now
Old Oct 10, 2006 | 10:30 PM
LS1Tech Sponsor
one will probably give you what you are looking for in most cases
__________________
Call 888-744-6542
Chris18927's Avatar
sweet, thanks
Old Oct 11, 2006 | 12:31 AM
05gto60's Avatar
its weird huh? the instructions tell you to rebuild it bass ackwards from how you removed it. i dont know if thats right cause the instructions arent infront of me, but if thats how its said in them, then yes. mine hasnt given me any problems at all
Old Oct 11, 2006 | 07:46 PM
Chris18927's Avatar
crazy
Old Oct 13, 2006 | 04:21 AM
PBA's Avatar
PBA
I agree with Vince, it is correct, except that I do not use any spacers in all of my builds.
