What causes an A4 to not Go when floored?
Old Oct 10, 2006 | 09:12 PM
Pro Mouse's Avatar
Question What causes an A4 to not Go when floored?
I dunno if I need the Tuning forum or A4 forum ,but when I am going down the road in Drive and Floor it the cars doesnt wanna go,It dont kick down and move.Not throwing any codes and I checked misfires and Have none.This isnt all of the time just sometimes.what would cause this?
Old Oct 10, 2006 | 10:29 PM
performabuilt's Avatar
LS1Tech Sponsor
use a scanner and look at the data stream at the tps throttle position sensor the value should change as the pedal is moved up and down , also make sure its plugged in securly though that would likley set a code but out of range might not as long as it wasnt higher or lower than max and min resistance
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 11, 2006 | 01:17 AM
DOUBT IT's Avatar
Traction problems. *points at his stall*
Sounds almost like what happened when I accidentally bumped my throttle adjustment thingy off. I put it back on not thinking, and was stuck at 80% throttle. Car wouldn't downshift at WOT, and wouldn't go over about 5500 rpm. When I figured out what I did, I smacked myself in the head so hard, I saw stars.
Old Oct 11, 2006 | 03:48 PM
Pro Mouse's Avatar
Question
I have logged TPS and seen it at 100% when it does this.But I didnt see what the TPS Voltage was? If it reads a 100% at WOT ,does this mean the Voltage is correct or is this 2 different things?
Old Oct 11, 2006 | 04:22 PM
LS1Tech Sponsor
what is it a idle
__________________
Call 888-744-6542
Old Oct 11, 2006 | 04:30 PM
Pro Mouse's Avatar
Old Oct 11, 2006 | 11:06 PM
Z2K_MrJ's Avatar
Board Certified Idiot
Hmm Possibly your Tranny is SLIPPING ??? hope its not tho
Old Oct 12, 2006 | 12:53 AM
TransAminal's Avatar
If you floor it...and the RPM's go up but the car doesn't accelerate...then the transmission is most likely slipping.
If you floor it and the motor starts pulling but it won't downshift, there might be something wrong with the transmission kickdown (probably electronic). Downshift it manually with the shifter, if it downshifts and accelerates like normal, you've found your issue.
