Transmission clicking problem New A4
Old Oct 12, 2006 | 10:36 AM
NemesisLS1's Avatar
Angry Transmission clicking problem New A4
Alright after the torque converter install on my new A4 there is a progressive clicking sound right under my center console. Theres nothing in the way of the driveshaft and I have no clue what it might be. I ordered a new aluminum driveshaft from summit yesterday to eliminate that problem with the u-joints and rusted out slip yoke.
But i have been told it might be something in the transmission... Its only got 2k on it.. And now i am going to be running into the problem with GM warranty with the new stall. Any ideas what the sound might be? its in the output shaft area..
Old Oct 13, 2006 | 11:09 PM
Spellbound's Avatar
My girlfriends car has that same noise.....I took it to a local Tranny shop and he said it might be a chipped tooth in the sun shell. IIRC.
Old Oct 14, 2006 | 06:30 AM
FLT's Avatar
FLT
Does it make this noise in 1st gear or is more noticeable in higher gears?
Old Oct 15, 2006 | 12:18 PM
xxxhp's Avatar
What would that indicate? I also have what seems like driveshaft vibrations at 4000rpm, which is most noticable in 3rd & 4th gears
Old Oct 16, 2006 | 08:39 AM
NemesisLS1's Avatar
Alright well I pulled out the old driveshaft and purchased a new one from Summit. Really really nice driveshaft!! No weights all one piece, and was super tight going into the transmission. Started it up and drove it around and absolutely no problems. No more clicking noise, no more clicking noises when placed in reverse, just great driving. Still have vibrations on highway but going to chaulk that one up to the retards that balanced my rims/tires.
Old Oct 27, 2006 | 01:20 AM
Spellbound's Avatar
My gf's car it makes the noise in the lower gears...makes the noise in neutral, with car off....
Old Oct 27, 2006 | 06:35 AM
FLT's Avatar
FLT
With the car off?
Old Oct 27, 2006 | 11:04 AM
Spellbound's Avatar
With the car off?
LOL, sorry...yes, with the car off rolling down a big hill by my house in neutral
Old Oct 27, 2006 | 11:49 AM
almostlive's Avatar
Old Oct 27, 2006 | 01:19 PM
Spellbound's Avatar
just pulled the DS...how much end play should there be in teh Tailshaft? I can push it up about an eighth of an inch and I can pull sown on it about a 1/4 inch.
Old Oct 29, 2006 | 07:28 PM
birdman97lt1's Avatar
could be a tc bolt hittin the tc cover have seen that many times
