A couple of questions after converter install
Old Jul 9, 2002 | 07:23 PM
REC's Avatar
REC
Default A couple of questions after converter install
This week I am finally having my Vig 3200 installed. When I pick it up is there anything that I should do as far as break in for it? Will I need to reprogram HPP3 shift points or is that something I will have to play with? Any advice would be appreciated.
Old Jul 9, 2002 | 08:50 PM
SAINT WS6's Avatar
Default Re: A couple of questions after converter install
you dont need to do anything computer wise. For the break in, run it through a bunch of different RPM ranges for a few hundred miles and you should be good to go.
Old Jul 9, 2002 | 10:31 PM
WILWAXU's Avatar
For the best times, you will probably need to tinker with the HPP at the track.
Old Jul 10, 2002 | 01:05 AM
TomQ's Avatar
yup, hhp3 or ls1edit
Old Jul 10, 2002 | 05:52 AM
MMI Z28's Avatar
make sure you have a tranny coller installed.
if so then you are good to go.
Old Jul 10, 2002 | 02:35 PM
REC's Avatar
REC
Thanks for the info guys. Hopefully TM won't be a major issue for me. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> How many miles would you guys say I should put on the verter before giving it a try? I really want to run this weekend but I don't think the car will be ready til Thursday. Thanks again <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jul 10, 2002 | 03:44 PM
MightyLS1's Avatar
The converter comes with a manual for break in. I followed there guidlines for proper lockup breakin then I went out and beat the hell out out of my tires.
