Thoughts on broken stator?
Old Oct 16, 2006 | 01:09 PM
y2khawk's Avatar
Default Thoughts on broken stator?
Anyone ever loose a stator before?
Had my truck freak out on me awhile back, started acting like it was slipping, then low on fluid, etc.
Park it, get the trailer, let it cool. When we came back it started and drove ok, enough to get it in the trailer.
Fast forward 6 weeks, as I lacked motivation to take it apart
Go to start it to move it inside, and no movement.
Get the trans out, go to take the converter off. It's stuck. Have to pry the converter off. Pen light inside shows the stator is at least 2 pieces that I can see.
Need less to say, the trans is being gone through again. And i'm sure all the bushings are smoked again. I didn't drop the pan, cause I know what I'd fine. The drain plug was fuzzy enough already.
Just curious if anyone has seen this before.
Old Oct 16, 2006 | 01:27 PM
cablebandit's Avatar
i broke a lot but never the stator. what converter you running?
Old Oct 16, 2006 | 02:40 PM
y2khawk's Avatar
It was a billet front cover TCI.
Old Oct 16, 2006 | 02:43 PM
performabuilt's Avatar
LS1Tech Sponsor
Typically a broken pump stator is due to a converter roller clutch failure .
performabuilt
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 17, 2006 | 02:22 PM
y2khawk's Avatar
OK, is that ultimately the fault of the coverter? Or am i killing converters for a reason?
#1 was a clutch failure, but i take responsibilty for that. 2nd gear WOT applies on a 10" converter with 5500lbs of truck and probably 650 to 700 ft-lbs DOH!
Old Oct 17, 2006 | 03:11 PM
LS1Tech Sponsor
Thats a bonified converter failure by its own right
__________________
Call 888-744-6542
Old Oct 30, 2006 | 07:43 AM
Kevin Winstead's Avatar
Harlan,
That's very unusual. I've only seen a couple 245mm stator break in the last 5 years. We offer steel stators for most applications. Give me a call and we can talk about your options.
Kevin
(662)224-9355
