Shifting too early? Need input!!
Old Oct 23, 2006 | 07:53 PM
2kta--89formula's Avatar
Default Shifting too early? Need input!!
My stock 4L60E has 88K on it. I have changed the fluid every 20K and it has never had a lot of debris in the pan. I installed a Yank SS3200 converter at 86K miles. Everything was fine, it performed flawlessly.
Last night I had a local trans guy install a Transgo shift kit. He put in two washers, upped the line pressure 30 psi <1/4 turn>, and installed the whole transgo kit.
The tranny is now short shifting on the 1-2 shift <5200-5500>. It used to shift just about at 6000, now it shifts at 5200 or so ONLY on the 1-2. The 2-3 is fine both on upshift and downshift Also, downshifting at 30mph the trans will shift into first, rev to 4500, then upshift into second. Is something amiss in the valve body/shift kit install, or is it in the tuning?
Old Oct 23, 2006 | 08:27 PM
Double post BTW with 92slomaro........
