Th350
Old Oct 24, 2006 | 06:00 PM
CarolinaWS6's Avatar
Default Th350
can a built Th350 hold up to a 1000 rwhp ? if built good
Old Oct 25, 2006 | 03:34 PM
i tired doing searches but couldnt come up with anything anyone
Old Oct 25, 2006 | 04:48 PM
Razor_Blade's Avatar
I have never had anything even remotely close to the power levels you are talking about, but most of the high HP cars that I have been around used a Powerglide or TH-400. I don`t think I have ever even heard of a TH-350 in a 1000 HP car. That does not mean that it has't or can't be done however.
Old Oct 25, 2006 | 06:34 PM
ss1129's Avatar
Ive seen them rated to 700hp....if that helps.
Old Oct 29, 2006 | 11:13 AM
PRAY HRD's Avatar
my th350 is rated to 950fwhp, however i would not try pushing it to that level. keep in mind traction, gearing, & weight will all play a part in how much you can punish any trans, not to mention hp & tq, and keeping it cool of course.
as stated, properly built p/g's or th400's are more commonly used & up to the task.
Old Oct 29, 2006 | 11:24 AM
8a8mfh's Avatar
Can I ask why?
It's going to be pushing the limit if you can modify the hell out of one.
It's like the stock 4L60E, most are pushing the limits and eventually failing.
If you can get one build to handle 1000 hp it's going to be failure prone.
Whats wrong with using a th400?
Old Oct 29, 2006 | 04:00 PM
revtime's Avatar
If you have enough money to build a 1000 RWHP motor then you have enough money to buy one of Kilgores superlite TH400s.
They start at $4500 but he reroutes the power path in the tranny and the internals he uses cut about 30 lbs off the weight of the trans.
Old Oct 29, 2006 | 04:28 PM
i was worried about weight with my car does Kilgores have ia website that i can check out
Old Oct 29, 2006 | 04:37 PM
ApacheDrill's Avatar
1000 is pushing it..it can be done with the right parts but 850 is about the range i was told a th350 should be in.. 1000 is alot of power..
Old Oct 29, 2006 | 07:29 PM
revtime's Avatar
kilgoretrans.com
