PT4000 vs. SY4000
Old Jul 15, 2002 | 11:23 AM
OBSSSD@work's Avatar
Default PT4000 vs. SY4000
Which one and why? I have a TR224-112 and will soon have the heads ported to match my cam. I will be running Nitto's all the time even at the track which isn't that much. I am currently running 3.23 gears so I was thinking the PT4000 with a 2.2 STR. My mods are in the sig...
Thoughts?
Old Jul 15, 2002 | 02:00 PM
Ragtop 99's Avatar
Default Re: PT4000 vs. SY4000
SY4000 is going to be a little easier to launch, but you're going to have to step into the launch for either converter. YTP is going to feel a bit tighter at lower rpms, say below 2500, but the SY may be a little tighter higher part throttle speeds. YTP will be better from a roll.
I had the YTP4000/3.23 combo. Got to be a bit loose for me and then I went to 3.73s. Had LS1 Edit been available, I would have raised my part throttle shift points and that would have tighten it enough that I might have kept my 3.23s. The YTP 4000 was easier to launch than I expected because the high stall gives you room to step into it. The 3.73s made it harder to launch because of the extra torque multiplication.
Old Jul 15, 2002 | 02:04 PM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by OBSSSD@work:
<strong>Which one and why? I have a TR224-112 and will soon have the heads ported to match my cam. I will be running Nitto's all the time even at the track which isn't that much. I am currently running 3.23 gears so I was thinking the PT4000 with a 2.2 STR. My mods are in the sig...
Thoughts?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Just to ley you know the lowest str you can have on a TP is 2.5-.2.6 area.I had asked to have mine lowered and thats what they told me.
