Manual valve body or trans go stick type shift kit for my th400?
my th400 is not shifting right, hits the rev limiter 3-5 times b4 shifting. what is the best thing to do to control shifting?Manual valve body or trans go stick type shift kit for my th400?
Thanks in advance
Thanks in advance
The TH400-3 will give you a full manual transmission (forward pattern) and it can be changed to full automatic in about 10-15 minutes if need be. This kit still uses the vacuum modulator (easier on the front pump), which will make part throttle shifts not so harsh, and has engine braking. I have installed many of these kits over the years and they work very well.
