why do big stall cars dyno so low? lets calculate.....
Old 11-09-2006, 11:36 AM
  #61
The know it all's know it all
Sean Collins's Avatar
Originally Posted by jimmyblue
I don't see how you can determine the converter's
efficiency without either a locked baseline pull, or
at least logs of slip RPM and engine RPM (but slip
only tells the minimum and not the actual efficiency
in the midband).
I have a Fuddle that demonstrates 96% (by slip)
at 6000RPM and is still climbing but I shift there.
True, I tasked them specifically for this, and the
big clutch, etc. How spy's piece compares, can't
say. But we are not that far apart on the stall/STR
specs (3400/2.1 vs my 3500/2.0).
I just look at so many graphs on a daily bassis i can see when something doesn't work right.
Old 11-09-2006, 08:08 PM
  #62
spy2520's Avatar
Originally Posted by CollinsAutomotive
I would hope the converter pans out when you start making more power with heads/cam and some other work. But looking at the amount of slip in the graph I'd say that you will most likely need a more efficient converter to get the thing to hustle.
well it doesnt hustle on the dyno, but considering my tires, my weight, and the fact that i only have 2 gears currently i'd say the car isnt doing too bad on the track...
Quick Reply: why do big stall cars dyno so low? lets calculate.....
