Help!!!!please Come In
Old Nov 3, 2006 | 10:44 PM
mattraypharbor's Avatar
Default Help!!!!please Come In
I need some help trying to diognose this problem...first of all i was leavin dinner and i was just acclerating in a gear and it made a loud bang noiise and i kept driving and it was fine i thought nothing happned...but when i left the place i was going to i put it into od and nothing it just revs up i dont get anything out of it...but when i manualy put it into 1st it works fine then i shift into 2nd and it works than 3rd then to od and everythings fine but when i try to floor the car it just revs up but if i leave the car in a certain gear and floor it it works fine no sliping or anything...under normal driving it doesent slip ither once its in od.....what do you guys think could be the problem because 1st doesent slip at all when i maunualy put it in and the tranny fluid is fine no burnt fluid all pink.... it looks a little low tho could low transmission fluid cause the car not to be able to move in od??? the car has a built tranny with a yank st 3500 stall and trans cooler and i dont see anywhere where its leaking.. im thinking it has to do with the shifting because when i floor it it feals like it just shifts itself into nutral...i dont have an ses light but i did have one the other day and it has happend before...shift selinoide b stuck open...also when i get it up to speed and its in od and i slow down to about 20 and start accelerating normal it feals like its shifting into all the gears from 1st all the way to 4th but once i floor it it does nothing help!!!
and if i go below 20 it doesent shift anymore and it doesent go anyware it just revs up...
Old Nov 3, 2006 | 10:48 PM
do you guys think low transmission fluid could cause this???
Old Nov 3, 2006 | 10:54 PM
bump...
Old Nov 3, 2006 | 11:04 PM
Old Nov 3, 2006 | 11:39 PM
bump...
stag mabey? again fluid is pink no metal or black besides a lil brown but not to much
Old Nov 4, 2006 | 12:06 AM
Old Nov 4, 2006 | 12:14 AM
performabuilt's Avatar
LS1Tech Sponsor
you either have a broken forward clutch sprag or a broken low sprag , If i move in the d position from a start its the forward sprag of it only moves from manual 1 its the low sprag
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 4, 2006 | 12:27 AM
ahh dammit i hate broke ****... is it an easy fix for my tranny guy...
Old Nov 4, 2006 | 12:50 AM
would it also cause some vibration under accel in the certain gear i put it in at high rpm??cuz when i was trying to figure out was going on i brought it up to about 4500 rpm in 3rd and i got some vibrations...
Old Nov 4, 2006 | 08:29 AM
LS1Tech Sponsor
It might depends on how it broke ,You just going to have to get in there and see what all has happened
__________________
Call 888-744-6542
Old Nov 4, 2006 | 11:07 AM
wow this sucks ***..
Old Nov 5, 2006 | 12:24 PM
anyone know how long it takes to replace a front clutch sprag?
Old Nov 5, 2006 | 06:31 PM
bump for another question
what do you guys think about me driving it 10 odd miles to the shop cuz i can manualy shift it with no problems...
Old Nov 5, 2006 | 06:32 PM
and once its in od the conveter locks and drives normal untill i floor it and then it basicaly downshifts to nothing..like nutral...
again no burnt or brown fluid..
