Th-400 crossmember??
Old Nov 5, 2006 | 07:23 AM
a98ws6's Avatar
Default Th-400 crossmember??
I see that Yank and BMR make one? Is there any other choices? I want to buy one so that I can re-use my BMR adj. torque arm. Thanks!!
Old Nov 5, 2006 | 10:27 AM
Yank's Avatar
You can use the T/A on your car with our crossmember and the price is at the lowest in ever
http://www.converter.cc/crossmembers/crosmembers.htm
Old Nov 5, 2006 | 10:34 AM
a98ws6's Avatar
Do I need anything to get this to work? Looks like I need a bushing or something in that bracket?
Old Nov 5, 2006 | 10:48 AM
Yank's Avatar
the aftermarket bushing that you have now will work.
Old Nov 5, 2006 | 05:20 PM
BTLFEDSS's Avatar
Thats what i'm running in my car a Yank.Stock torque arm and a energy suspension urthane bushing.Nice piece and you can't beat the price
BTLFEDSS
Old Nov 11, 2006 | 09:17 AM
91camaross's Avatar
if u get a tunnel mounted ta cant u just use a 6speed crossmember
Old Nov 14, 2006 | 06:35 PM
SSPerformance's Avatar
seems to me the m6 and the th-400 ones are the same on the yank site is this correct?
Old Nov 14, 2006 | 09:44 PM
revtime's Avatar
The BMR M6 and TH400 are different. If you use an M6 crossmember with the TH400 the tranny comes down too far.
Old Nov 15, 2006 | 10:54 AM
Yank's Avatar
the crossmember is the same, but extra parts are sent with the M-6 model
Old Nov 15, 2006 | 02:54 PM
s Yank is this true do i need a spacer i have ur m6 crossmemeber and i will be runign a th400
Old Nov 15, 2006 | 03:32 PM
Yank's Avatar
when used with aTH400 no spacer is used or needed as the correct angle is set if the 1990 gm truck with TH400 rear transmission mount is used
Old May 21, 2007 | 10:54 PM
SuperC1's Avatar
What extra parts come with the M-6 model?
and what is the part number for the 1990 truck transmission mount for the th-400?
Old May 22, 2007 | 11:01 AM
john kilgore's Avatar
Default X mem
l have a number of camero- f birds with my th400 superlites and l think the 6 sp x mem and a 2-3" spacer seems to work good luck
