T/C Not locking...Help
Old Nov 9, 2006 | 11:22 AM
MRZ28's Avatar
Default T/C Not locking...Help
When im driving down the highway at say 70mph the converter will just slip out of lock up, when i turn the car off (whil driving) and back on it locks up right away, and then a minut or two it will come out of lock up again. Now i recently had the tranny rebuilt as well as the T/C, so everything is new, and it is still doing the same thing. could this be a tunning issue??
Old Nov 10, 2006 | 08:41 AM
MRZ28's Avatar
TTT...Any Help would be appreciated
Old Nov 10, 2006 | 10:58 AM
Joel_SS's Avatar
Yes more then likely tunning.. I bet you are getting randon missfires.. Even if they are not enough to through a code it will still lock/unlock the verter.. Have a tuner bump up the mis fire detection tables for you. Very commom problem with a cam
Old Nov 11, 2006 | 03:04 PM
AutomagicLS1's Avatar
Im in the same boat as you waiting to get my P0757 code shut off. For 2 days lockup was completely gone but yesterday it came back....damn computers
Old Nov 12, 2006 | 07:27 AM
DRIVER456's Avatar
I had the same problem after a cam install,I have EFIlive and I had to set {C5601}MISFIRE DETECTION MAX TEMP from 266 degree's to 1 degree and it solved the lock and unlock TC problem.I don't know if it will solve your problem,But you can try that.
